valve seals or piston rings, orrrr....???? need some help with oil burning
not sure if anyone has been following my restoration project… but i need help or ideas…
i have a 92 gsr, bought a brand new re man type r motor to throw in it for the meantime while i build the b17 back up. put the new c5 motor in, started it up sounded awesome. everything went good. took it for a ride, and i just noticed clouds and clouds and clouds of smoke behind me, and when i would stop it was literally engulfed in clouds where i could not see out of the car.
called honda thinking it would be the piston rings, got a whole new block warrantied, but i havent put it in yet, took the motor out today, and took the head off the old block and noticed the exhaust ports were coated in raw oil as well as oil in the throttle body as well…
put the header down on the floor, came back to it an hour later to see a puddle of oil that came out of it.
do you think its the head or block or both? valve seals, piston rings??? idk. i need help. cuz i want to put the motor back together and in tomorrow but i dont wanna rip it apart if the new block wont solve it. maybe ill just do new seals regardless??? help!
New valve seals should do it. But you probably have about a quart of oil in the exhaust system by now - expect more smoke when you start it up untill it burns off. Been there - Done that.
First of all. I would post a link to your build thread.
Second, I assume you have blue smoke b/c you found oil all over the place. Was your PCV valve working correctly? I have had oil being sucked up into the intake manifold b/c the PCV valve went out. I would check the hose and see if it’s got a lot of oil in it.
So you got a remanufactured engine and you think it has bad valve seals? Remove the valve cover and take a look at them. If they are new, make sure they are not f*ed up when installed. I doubt all of them would go out at the same time. Usually when a valve seal goes out, you get a puff of blue smoke at start up after the car sat for a while (over night time frame). After that it usually won’t smoke like crazy all the time unless there is total failure happening. They could have been installed improperly. So, I would check to make sure the seal was installed properly.
