Valve Spring removal?
How the heck do you get them out?? I have the head off and i can’t get a valve spring compressor that can fit in the to get at them :argh: Anybody have any suggestions? I would love to hear them!!
thanks:up:
nobody had done this?
you just have to find the valve spring compressor that fits
Get a valve spring compressor that looks something like this and a 19mm deep impact wrench socket.
Then cut a slot into the 19mm socket that looks something like this and use a bolt with a nut and washer to secure it to the valve spring compressor.
Works great. I’ve done several valve spring installs.
or you can get a socket and just give it a good swift tap on the retainer until the keepers pop off, but mind you putting them back on manually is a PITA
dayam… that would be a MAJOR PITA
