I have been fighting with this vibration for a while. I read a post that said to clean the eacv. This weekend, I removed and cleaned the EACV. It has a screen that filters the incoming air, it did have some debris on it. After putting it back on, I had to reset the idle speed, I then reset the computer. The vibration is still there but maybe it is a little better. The idle sped is a 650 rpm w/o EACV connected, and it idles around 725-750 with the EACV connected. The vibration gets much worse when I turn on the AC, but the idle spped stays up where it should.
I am using the prothane motor mounts and inserts which definitely makes the problem worse. But I have driven integras that the engine did not vibrate at all.
Anyone had any luck solving this problem? Any help appreciated.
93 Auto, 1.8L
