The car has the typical symptoms of bad axles, but they are brand new (days old). Im running out of options. I love my car and I do not want to get rid of it but its driving me to that point. any feed back would be great.
01/2011: Had the car about a year, axles went bad so I replaced them along with the lower ball joints and outter tie rods: still had a little vibration in the front end.
09/2011: Noticed the front engine mount from the cross member to the trans. was shot, I thought that was the culprit, replaced it. I also replaced the front upper and lower control arm shock mount and sway bar bushings with ES bushings… still had a vibration.
10/2011:Replaced the axles again a few days ago, and it still has a vibration.
again, I love my car and Im getting sick of this vibration, I do not want to get rid of it simply because I can not figure this vibration issue out.
Im running progress coilovers with their 350F/350R spring rates. I have the ride set to 12 1/4 inch from the fender to the center of the wheel up front and 12 1/2 inch in the rear (Just as progress recommends)
I’m not a mechanic or anything, but…maybe your intermediate shaft? I was told that by VIP Performance about my DA(they said maybe), still shakes but I just got axles and hope that fixes the problem…one question though, where did you get your new axles?
All i know is replacement axles from auto zone or Napa don’t have a rubber balancer on the axle. its right in the middle. Raxles are an oem quality replacement axle…quite spendy i paid about 400 shipped…but they are oem quality and i hear a lot of people saying they had a vibration after Napa’s and finally bit the bullet and got Raxle axles and it cured all problems. And i don’t think your too low, im lower than you and didn’t have a vibration just until recently. and i think that its because i have the shitty Napa axles with less than 5k on them and already have a torn boot. Im going to install the raxles this next week and ill let you know the outcome…
