VIDEO : Annoying dash noise - not the speedometer cable.
I have this squeak coming from my dash area that is driving my nuts. It seems to happen mostly when the car hits bumps in the road. I’m hoping somebody on here might have had something similar or might be able to help me narrow down what it might be.
http://www.youtube.com/watch?v=6lUfQR0vZIA
http://www.youtube.com/watch?v=WZiwfokTJFE
do u have ES bushings by any chance?
Just the shifter bushings. They’ve only been on the car for about a 1 year.
i’d lube ur bushings first. but chec all the plastic parts on ur dash.
u need to isolate the location of the sound. get a friend or someone to help u do that as u drive around.
something’s definitely loose but iono what. have you check behind the stereo or underneath the steering column? check and tighten any screws/bolts u see. trial and error i guess.
When my heat is on it sounds like a cricket is in my car. lol
that is what it sounded like when my struts and bushings went bad.
two replys saying bushings. Do worn bushings really sound that loud? I swear the noise is coming from the inside of the car.
sway bar bushings are bolted by brackets onto the frame of the car. that is basically right under ur feet. metal on metal is pretty squeaky/loud. metal on polyurethane bushings are kinda irritating too.
we can’t be 100% sure on the cause… but if u actually did some investigating instead of looking online, u might get somewhere. eliminate what it is not first, then move on. eventually you’ll find what is causing it, or u can give us info on what u have checked and found not to be the source of the noise.
It goes without saying that I am and will check further where the noise is coming from. I was just throwing it out there for by chance someone might have had the same problem. The noise is really getting to me and the sooner I get it fixed the better.
the problem with throwing it out there is that… there is a LOT of places it can be coming from. but if u can narrow down the source area, then we can throw ideas at u that u can work with.
cuz getting input from someone saying “check your exhaust hanger cuz thats what was squeaking in mine was, and i replaced it and it went away” is NOT gonna help u one bit. cuz trust me… SOME !@$%!^@$! on here will prolly say something like that and be totally serious.
