Visors
I’m a little curious about window visors. How exactly are they mounted? I know any visor I’ve seen mounts above the window to the door. But if the Integra doesn’t have anything above the window to mount the visor to, how does it work and still be able to open the door without leaving the window down?
They mount by four clips that attach to the trim along the top of the windows and rear quarter panel glass and double sided stick tape (on that same trim). The fit between the visor and the window as the door opens is perfect, it just clears right under with no hitting at all. OEM goodness :up:
Here’s a link to the “Window Visor Club” in which you can see more pics of installed visors.
http://forums.g2ic.com/showthread.php?187412-Window-Visors-Club
But, to make things easier, here are some pictures I took of my visors. You can see how they mount and where the clips are located.
Starting from the back of the visor to the front, the first clip:
Close up on the first clip:
Second clip (above the door):
Close up on the second clip:
Third clip (between the front windshield and door):
Close up on the third clip:
Last clip, right above the mirror:
Close up on that fourth clip:
Here’s a front shot of the visor installed:
Lastly, a side shot! Here you can see where the clips are located on the trim and the spacing in-between.
