VSS ECU code
So my ECU has been throwing the 17 code, which is for the Vehicle Speed Sensor. My speedo works, my odo works, I reset the ECU through the Teg Tips instructions and it still throws it as soon as the car is turned on.
Little background info on the car, it was swapped from auto to manual and I’m wondering maybe that’s why it’s throwing the code? Is that the reason, or could the VSS be going bad?
What are some options that I have?
Coz
im pretty sure its because the car was changed from auto to manual.
as to fixing it, im unclear of what to do. sorry…
-karlo
Any other ideas?
sounds like bad VSS somewhere cause i just completed the auto to manual swap myself and still have the auto ecu and no codes for it. no codes period actually
Yah, I mean I put a manual year specific ECU in mine with the swap.
If the VSS is bad wouldn’t I be having issues with the speedo or the odometer?
yea true that is wierd how it can be throwing a code for a mechanical sensor??? i’m stumped hahaha
Are there any physical symptoms of it being bad? Is it worth even bothering if my speedometer and odometer are fine?
Bump?
Still having this issue. Even put in a new speedo cable and nothing.
The VSS is in the cluster, it converts a manual signal (spinning cable) into an electrical signal for the ECU to process.
  1. try swapping the cluster
  2. if that does not work test the VSS wire at the ECU.
  3. if you have a signal at the ECU make sure that the harness pinout matches your ECU.
  4. If you have a signal at the ECU and teh pin out is correct then the ECU needs to be replaced.
I thought the VSS was on the actual transmission? Where the speedo cable plugs into?
I’ll check the ECU info you gave me over the weekend.
Coz
The unit on DA transmissions is a gear that connects to the speedo cable. The electronic part is built into the speedometer in the cluster. On newer Integras /DCs they made the VSS on the tranny electronic (wires no cable).
