Just recently, my car will sputter after I go over a large bump (will practically stall if I try to launch it at normally rpms, 1500-2000). My engine check light will come up and idle will bounce from 750-1500. Once I shut down my car and restart it, the problem will go away. ECU flashes 3 short (MAP sensor?). Checked the connections on the vtec controller and it seems to sputter when I move one of the wires, I can’t figure out which one though since they are bunch close together. Checked the ground wire on it and it looks ok. Does anybody know if this can cause the car to throw this code? Any ideas which wire maybe the cause or can this be cause by something else. I had recently swapped ECU chips, so I have unplugged the harness a couple of times but didn’t have any problems until now. Thanks for the help!
1.7NA
