Trying to clear some space in my garage so i’ve decided to sell some of my spare parts. These parts are priced to SELL!! Im only asking half of what other people are asking for the same parts!
Will ship items but the cost is the buyers responsibility.
GSR Oil Pump - used but in great condition. No wear on the rotors or on the inside.
$50 OBO
92-96 Prelude Vtec Fuel Injectors H22a1 - 340cc peak & hold fuel injectors OEM. Great condition.
$60 OBO
Rota Grids 16x8 +20 offset - only has 3 tires with about 3-4 months left on them.
$700 OBO
90-91 Civic Si Front Seats - these are in MINT condition! Which os very rare, considering the age of these seats. No rips, tears, stains, weird smells and the foam is still plump, not fagging or flatened.
$200 OBO
OEM 92-93 Integra Gauge Cluster - everything functions properly as it should.
$25 OBO
Carbing Radiator Cooling Plate 96-00 Civic - Pretty rare piece. Directs air to the radiator instead of flowing past it. Makes the engine bay look so much better! -
$60OBO
Complete OBD2 LS/B20 Head - perfect condition, pulled for GSR head install.
$85OBO
Perfect OBD2 LS/B20 Valve Cover - no paint chips or anything.
$25OBO
Tokico HP Struts 90-93 Integra - Full set, including front & rear. These are in good working condition and none of the struts are blown. I also have the front forks for these.
$160 OBO SOLD
OEM 90-91 Integra Starter - Part # 128000-7080. Have the piece of mind by using quality OEM parts. Just replaced the solenoid contacts.
$35 SOLD
OEM 90-91 Integra Alternator - Part # 100211-9850. Good working condition. High quality OEM part, not 2nd hand aftermarket junk. Recently tested & passed at Autozone.
$60 OBO.
OEM 92-95 Civic Ex Alternator - Part # 100211-9770. Works flawlessly. Interchangeable between all obd0 and obd1 B series motors. Tested & passed at Autozone.
$60 OBO.
OBD1 PR4 ECU - off a 93 Integra but is compatible with all obd1 B series Hondas/Acuras.
$40 OBO
OBD2 LS Intake Manifold - Complete including fuel rail, and injectors. also includes the FITV, and the IACV.
$40 OBO
Obd1 FITV & IACV B Series - These will fix your idle issues! Great condition and cleaned properly.
$25 each
Obd2 IACV B Series - great working condition.
$25 OBO
94-01 Integra Shift Linkage -The joint has absolutely NO play! Installing this will get rid of all the play in your shifter. So it will no longer sway side to side while in gear. This will also work on DC Integras as well as civics with B series swaps.
$45 OBO
Multiple Shift Linkages some D series some B series -
$35 OBO
Miscellaneous B Series Engine Mounts - $OBO
Also have multiple vibration brackets & A/C brackets for EGs/DCs
Cable Vehicle Speed Sensor - worked on both my LS transmission, and my jdm b16 trans.
$25 OBO
Electronic Vehicle Speed Sensor - originally out of a 95’ Civic Ex
$25 OBO
94-01 Integra Half Shaft - This will fit on all B series Hondas/Acuras. Male half shaft.
$25 OBO
90-93 Integra Half Shaft - This will fit on all B series Hondas/Acuras. Female half shaft.
$25 OBO SOLD
90-93 Integra Engine Bay Fuse Box -
$10
Two Hoosier DOT Radial Wet H2O (Track & Competition DOT) P205/45/R16 (pair) - BRAND NEW!! Has never been mounted or installed. Still retains original stickers on tire tread. These tires retail for $244.00 EACH! These are racing tires, and as such are super wide when compared to none track tires that are the same size.
$150 for the pair!
Hoosier Sports Car D.O.T. - Radial Wet H2O tires were developed for drivers who participate in autocross and road racing events in moderate to heavy rain.
Like all Track & Competition DOT tires, Radial Wet H2O radials are not intended to be driven in near-freezing temperatures, through snow or on ice. It’s also essential these tires be stored indoors at temperatures maintained above 32 degrees F.
Sports Car D.O.T. - Radial Wet H20 tires feature an aromatic oil-free wet weather tread compound that offers traction for fast and consistent lap times in wet track conditions, along with improved treadwear and durability in damp to drying track conditions. This compound is molded into a directional tread design featuring a combination of circumferential and “Y-shaped” lateral tread grooves. Through the initial portion of their life (between their beginning tread depth of 8/32-inch and approximately 4/32-inch of remaining tread depth), the walls of the tread grooves taper as the tires wear. Through the remainder of their tread depth (between 4/32-inch tread depth and worn out), the walls are molded vertically. This allows the tires to serve as full wet tires when used at their original 8/32-inch tread depth, or intermediate wet tires when shaved or worn to approximately 4/32-inch of remaining tread depth due to the reduced tread squirm and increased footprint contact area.
Sports Car D.O.T. - Radial Wet H20 tires have a symmetric internal construction and directional tread design that allow them to be mounted for use on either side of the car. The tire’s internal structure features a three-ply nylon cord radial carcass reinforced by two fiberglass belts and a spirally wound circumferential nylon cap ply under the tread.
OEM ITR Trunk Brace -
$50 OBO
H Series Vtec Solenoid - complete and in perfect working condition with month cut wires.
$30 OBO
B Series Vtec Solenoid - Great working condition.
$30 OBO
Contact by TEXT 2068537953 or send me a message on here.
