Like-new wedge engineering driver’s-side bracket. Confirmed fit. 1990-1993. $80 shipped.
Brand new Hardrace RTA bushings for 90-93 integra. SOLD.
Would you be able to use side mount brackets on that seat bracket ?
Most likely. These brackets were drilled from Wedge to fit with the stock steel side mount brackets for the Bimarco Expert Racing seat which seem to be a pretty universal design. Most side mounts have multiple slots which allows adjustment in both front to back and some side to side adjustment. If that doesn’t work, you can also redrill the four holes you see on the bracket since they are mounted with thru-bolts/nuts.
da9leo,
You’ve had the money request since Monday, change your mind?
alright man I might be talking back to you around Thursday. I got sparco side mounts for my sparco rev and I really don’t want to drop $140 for a seat bracket lol. but as far as fitment goes, have you tested to see if this lines on with the stock holes?
Yep it fits, I had it in my car for a little bit before going back to stock (pro-tip: make sure bucket seats aren’t too snug before you buy). You might be able to see in the photo where I took a dremel to open up the mounting holes a little to get proper fitment.
ill take the bushings if they are still for sale
Sounds good, they are. Paypal my gmail acct “ar.thousand” or list your paypal acct so I can send you a money request
Are the rta bushings still up for grabs?
Depends upon if fish makes payment on them. I’ll give him some time do do so, otherwise you’re next in line.
