Want to make manual lock into power lock
Hey i have a 91 ls and i want to turn my locks into power locks so i can use keyless entry with an alarm… i have the oem door actuators off a gs model and door panels with door lock switches also off a gs model…im not a genius in knowing which wires are what and where they are supposed to go but i can do my own handy work once ive been told what i need to do…
Questions:
I know i need a relay or whatever but im not sure where to find it.
Do i need aftermarket actuators or can i use the oem ones if i plan to do keyless entry.
If i do need aftermarket actuators do i need a 2wire (slave) or a 5 wire (master).
I need to know how to to wire it all up. Basically which wires i need to connect to what and where to get power from…
Any detailed wire diagrams and pictures would be most helpfull, as im an idoit in trying to understand peoples writing.
Im pretty sure theres a thread with all this layed out so if someone can link me to it i would be grateful. Im new to g2ic so not sure how to find what i want amongst all the other stuff.
I’ve have 91 factory service manual that I no longer need and will sell if you want wiring specifics using oem parts.
I looked into this when I was considering buying my buddy’s 91 LS and wanted to add oem power door locks. From what I have researched, you will need a gs cabin harness or just the wires specific for the door locks, gs doors would be best for the for door wiring harness but if you don’t want power windows then just wire specific for the door locks. You will also need the door actuators, power door lock control module, and the appropriate fuses. I am not familiar with the rs fuse box so just double check that.
I can email you more specifics if you like with some pictures.
Pair this: http://www.deiproducts.com/servlet/the-62/524N-DEI-2-dsh-Wire-Power/Detail with virtually any aftermarket alarm.
They install to your lock-rod inside the door. When signaled by your alarm, they lock/unlock the doors. Easy peasy.
