i was going to see if anybody knows how many washers i use to correct my camber in the back. my back left is at -2.1 and my back right is at -2.5. thanx in advance
i think it’s pretty much trial and error… i think if you look around you might find a specific thickness will adjust it so many degrees…
Yeah depends on the size of washers you buy. I used two on each bolt and still have -1.5 camber which is what I want… better for turns. I’m running about -2.5 front and -1.5 rear…
