water in lenses
i just washed my car and notices quite a bit of water in my corner lense. What can I, should i do?
They are pretty new too.
Thank you
stock/clear corners/jdm/projectors?
clear corners.
Just out of curiosity what difference would it make except if they were projectors?
stock - reflector and clear piece of plastic can split at the seam… on the outside, on the actual lense…
clear corners - may have a leak somewhere in the back area… because the lense is 1 piece…
jdm - :shrug: forgot… i dont think it can be just the corners on jdm’s… iunno why i added it…
projectors - wanted to know… because i wasnt sure about them…
just go along the back with some silicone or the stuff that people use for sink/tub filing
Buy a silicone or some form of leak sealer. Something that can compress and expand in different temperatures. Put that on around the seal line on your lenses and it should seal it right up. Make sure it’s dry before you seal it. DO this by shaking it to remove water and using a lamp and or hairdryer to dry the water up. Be careful not to melt the lense.
Mike
I have been getting some moisture in my corner lense also. It is a stock style. I did what you guys said. I siliconed the edge all the way around and it is all misty inside again. I didnt see any cracks on the edge of the reflective part. So any more suggestions?
Thanks
i had the same problem as AZNT. there are little rubber “L”-shaped pieces that are like drains. well, i just drilled a few holes towards the bottom to let the moisture out. it seems to be working great now.
well thanks for the tip. I think I will try that. I think i found a small hole on the lense. It looks like some one tried to do the same thing but I think should not be on the front. I will drill one then. Where abouts did you drill it?
Thanks
