I was planing to replace my valve cover and spark plugs, and when I took off the 1st cylinder plug, i notice some oil on the plug, and than looked into the 1st cylinder hole and saw lil oil on the spark plug metal part. I continued on until the 4th cylinder and then when I pulled the wire out, there was some nasty stuff on it, and my heart went kaboom, when I saw good amount of water in the 4th cylinder spark plug hole omg omg. I’m going to try and pump out the water and then changed my spark plugs and wires. Is there going to be problems?
in case it helps…One time I washed my engine bay and flooded the damned spark plugs in water. I had to use an old t shirt and a stick to sop up all the water and clean them out. Once it was out though, the car started up and ran like a champ.
I just poked the shirt down into the holes with a long stick, piece of metal or whatever, and kept doing that until it was completely clean. Didnt take the valve cover off. Make sure you get all that water out before you pull the plugs to take off the cover…
so if a person has a b18 non vtec head, they should also look for a sparkplug cover because it will keep the water out? i doubt that the vtec sparkplug cover does much to keep the water out as it does not have a seal. the trick is not to spray the area at all. if you have to spray, maybe put a rag over it or something.
my moms B20 and my LS motor both have no issue with this. i wouldnt doubt that the spark plug wires are shaped different on LS/B20s than on VTEC heads, probably creates a seal on its own
ahhh, you are talking about the dust boots on the plug wires! i thought you were talking about the spark plug wire cover (plastic piece that goes over the spark plug galley in vtec heads) since the picture looks like its of a vtec head.
the O-ring gasket around the spark plug tunnel is slowly leaking and your spark plug top boot is obviously not sealing… common problem. no worries. ez fix.
read what he said …the previous owner did wash the engine bay… the white goowy stuff could be the rubber boot deteriating when oil, water and heat are present at the same time.
i got new plugs and wires and new oem vc gasket set. and now it runs like a champ. one more question, does anyone know if a b18c timing belt, tensioner, and waterpump will work with my b17a? thanks
another way to fish out the water would be to grab a straw, dip the straw in the hole, use your finger and plug the top part of the straw and just take that water out.
its kind of like when you put a straw in soda or something and then you plug up the straw and the soda stays in the straw even when its out of the cup.
you could either do that or suck the straw(no homo) and just dump the water out afterwards…
just be careful not to swallow it.
:naughty:
