i have a leak in my trunk put new taillights in and sealed the draining tubes so they dont come out. its pissing me of cause i have some subs i want to put in
did you put in new taillight gaskets or did you reuse teh old ones?
i used the old ones but they were not bad. i also used a clear sealant around them in the inside and i put a house over the trunk part and no water cam through them. its coming from somewhere else and i can seem to find it.
what do you mean you sealed the drain tubes? The waters got to go somewhere, if you seal the drain tubes then water will just pour over your head from the sunroof because theyre not draining.
i sealed the tubes to stay in because they were always coming out and water was getting every where but now its coming from some where else and i have water coming from the passenger side belt where it goes back and forth
