water leaking inside need help
sothis moring i went to go and start my car and i turned on my heater and i looked over and there was water leaking on to the passenger floor when it was on so i turned it off and it stoped so dose anyone know what might be hte problem…???
THanks
There used to be a Teg Tip that covered this. I need to fix my leak, as well. It seems like a drawn out process, but it’s mainly just time-consuming (the process itself is fairly easy).
You should take a look at this thread. The tip from Australia is particularly good.
you really gotta be shittin me. this was my first problem and quite possibly the easiest to SEARCH for and find the answer too. jeez im a noob here and i gotta tell you to search. :search: :tsk:
it couldnt be made any easier…teg tips buddy
http://g2ic.com/tegtips/interior/15.html
…there are many more solutons to this problem if you search…
