water leaking
my back hatch is leaking water… and as far as i can tell the whole seal it touching… i tried putting armorall on the whole thing and it picked up dirt from under the hatch all the way around… anything else it could be?
tail light seals. Easy but pricey fix if you get new ones. Me, I used some foam weatherstrip from walmart
tailight seals would make it leak into the hatch? it does it whenever it rains tho… not just when i wash and hose into the taillights
it is only on the passanger back right behind the taillight tho… how much do honda seals cost? (just one side if i can buy like that
yeah tail light seals will cause that, I don’t make this stuff up I speak from my experience. They are about $20 each from honda last time I checked. Like I said before I used a $3 roll of foam insulation from walmart and it took care of that. It could be other things like the sunroof drain tube, I was just giving you a suggestion of where to check first.
Dude, you’ve been here long enough now that you should know to check the TEG TIPS and then do a search before you post. This is SUCH a common problem…
Hi! Are those taillight gaskets OEM 33503-SK8-A01 or what is their number? I use this site http://www.acuraoemparts.com/delray/jsp/home.jsp to check the OEM numbers. But if some one could make it sure, that those are what I need if my 4dr LS leaks water into the trunk, I would appreciate it. Thanks! :slight_smile:
Thread from the dead …
:cookie:
