Water leaks EVERYWHERE...when it rains.
Hi Guys,
I just found your great! site and have spent a few hours going through the message boards looking for a fix for my problems.
I know about the Teg Tips about the water leak on the passenger side floor. I am going to pick up the caps at the dealer as suggested by the Teg Tips.
My problem is that I am also getting water on the DRIVER side. Same situation as the passenger, basically nothing else appears to be wet but the floor. Could the whole passenger side leak thing be causing my DRIVER side to get wet tooo?? Is it possible that when the blower gets full enough water makes it over to the diver side??? Any Ideas?
I have the cowl off as well as the blower cover and want to make sure I get this right the first time.
Also, if this were not bad enough it appears that I am now getting water through the roof on the passenger side…water is coming through the motorized seatbelt track!!! Any ideas how to stop this??? The car has never been in an accident or anything…these leaks are diving me CRAZY!
Any input will be very greatly appreciated.
Thanks
-K
check if ur a/c tube is cloged. hmm if u got a sunroof check the tubes on that and the drain holes. check ur weather strips.
Hi,
Don’t have sunroof. Where is the AC tube? Could this get full with rain water?
Thanks!!
its under the pass. side. right under i think the a/c compressor.
Thanks! I will check that out today.
