Hey guys, im going to do the whole timing belt-water pump change real soon and i was wondering which water pump is right at this link, HERE I have a 91 rs THANKS
That depends on what kinda engine you have. The engine on the top is for the vtec gsr, and the bottom one is for the non vtec. if you look at the oil caps, u can tell the difference. HTH. I did the water pump and timing belt on my car as well. Hope u have a chain wrench to get the crankshaft bolt off. Good luck
