Ok so i have a spare motor b18a1 that came off a 95 ls integra and with that being said it leave me to believe it isnt the original motor it had. According to some forums all b18a1 motors are from 90-93 integras and b18b1 are from 94+.
Any ways I want to replace the water pump for it before i drop the motor in my teg and the dealer couldnt help me figure out what water pump i need.
I told them the motor is a B18A1 90-93 LS but it came from a 95 teg and i just need a water pump that will fit a 90-93 LS motor. The guy said he couldnt help since all motors have different and speciffic water pumps depending on year… So a 93 ls water pump was not the same as a 95 LS.
Is this true or did i miss something along my path of being a grease monkey.
yes they are i took my w.pump off my 91 ls and used it on my 94,95 b18b no issues here…u jus cant use a vtec pump i kno that the gsr has less teeth on the gear itself than an ls
actually the vtec pump can also be used on an ls you just have to use the vtec timing belt i believe. and possibly the vtec crank sprocket as well. is something along those lines.
but yea i think he was giving you the run around cause all non vtec b-series are the same
