Will coolant pour out if the water pump is removed? Draining the coolant necessary?
stop trolling
read the fsm. if you dont have it, get it. if you dont know what it is then youre wrong.
wtf is going on here…
Yes, and yes. Coolant will pour out even if the system is drained
Darn Really? Do you think a flush will prevent coolant from gushing out? As of garden hose flush.
Then you’ll be leaking water… lol
I had my system drained for about 2 months before I pulled my water pump, that included removing the front block plug and draining the coolant from around the cylinders. Some coolant still came out from the water pump, by some a mean a very small amount. It didn’t gush out. Just drain the system and you should be alright
