water temperature gauge maxing out, check engine light on and blinker lights on.
ok so, i swapped all the parts from a 93 integra over to a 91 and converted it to obd1. but now that everything is hooked up it is acting really odd. the car starts, but when i turn the lights on, the coolant gauge completely maxes out, the check engine light comes on, and both the blinker arrows light up. also when i turn the key two clicks i hear the fuel pump prime and the green blinker arrows light up like the check engine light normally does when the fuel pump primes. and the check engine light lights up but just stays lit up. even though all this is happening the car still starts right up and idles normally but when it is idling the tachometer doesn’t move.
i would have thought this was a ground issue but i can’t seem to find any bad grounds, i have cleaned like three under the dash and a few in the engine bay and one in the back by the tail lights. am i missing some grounds?
it sounds like i mixed up some plugs but i don’t think you can do that because they are all different shapes. Does any body know where the plug or sensor for the tachometer is? maybe i didn’t get it plugged in and that is causing all this trouble.
any ideas/help is appreciated. thanks guys!
bump for an answer
I’m not 100% sure on this, but I got the plug near the distributor cap wet once and it cause the tachometer to not work like you’re saying. So check that wire harness there.
Is the ECU throwing any codes?
So you replaced the ecu, and distributor correct? As far as the sensor for the tach, that would be in your distributor. I know that when I’ve had ICM’s (ignitor) go out, the first thing that starts happening is that the tach starts bouncing. Maybe you mixed some of the wires up there, since you converted to obd1. If you didn’t switch to an obd1 distributor, then that may be your problem. I don’t believe an obd0 distributor will work with an obd1 ecu… At least not without rewiring it.
i havn’t replaced the ecu or distributor, but they are both obd1 and were working in my other car when i used them there, i will check the wires around the distributor, is there a ground in that area that i should check too??
Ok, so you swapped EVERYTHING from your 93 to your 91 including the wiring harnesses. Got ya. You might check the ground that’s on the water neck too if you haven’t already. It should be down on the block behind the distributor. That’s the main ground for the sensors and ecu to the block.
is that the one that kinda “plugs” into it?
No, that’s a ect switch. There should be a ground down there somewhere too…
the ecu doesn’t seem to throw any codes but the check engine light does come on when i turn the lights on but that is it.
anybody know why the coolant gauge would max out like that? i can’t figure it out. has this happened to anyone before?
