Did a search and couldn’t find anything about my particular problem.
I drive a '91 DB1 and today when I got back in my car after running an errand, the seatbelt wouldn’t return to the back position when I closed my door.
I messed around with it a bit, checked the passenger belt which works, turned off car/unplugged seatbelt box/started car/turned off car/plugged box back in…still doesn’t want to go back when door is closed. It emits a series of beeps and belt light flashes every 5 minutes while I’m driving…and sometimes if I lock the driver door while the car is on, the seatbelt beep emits a single tone which is weird as hell.
Not sure if this is relevant…but lately I guess my fiancee has had a few problems with the driver door sticking, not wanting to latch shut, sometimes hard to open. I also recently swapped the power window motor on that door, nothing was modified or messed with other than some grease added and window adjustments made due to rattle.
Anyone else have this problem, and figured out a way to fix it? How does the seatbelt know when to return? Is the mechanism built in to the door latch? It doesn’t rely on the door switch, that only seems to control the dome light.
Note: I called Acura already. Technically the recall/warranty for seatbelts is only supposed to cover the lap belts not latching. In some cases, I’ve heard of people with my problem and they had it fixed for free at acura. Anyways, the Acura here told me it’s $55 just to figure out what’s wrong, and he’s almost positive it won’t be covered by any recall or warranty.
EDIT: Went out there and used WD40 on all the door hinges, door latches and dome light switches. Driver seatbelt is still having the same issue. After some more searching I’ve realized a lot of other people are having the same problem…everyone says go to acura, no one offers a fix. There has to be some way to fix this without paying out my ass for Acura to do it…read above note I made, they won’t do it under warranty for me…plus they aren’t really local so factor in gas money as well. Not an option!
EDIT2: Found my spare seatbelt control box, swapped it in…still having the same problem. Does anyone have any ways to fix this? I need this fixed asap, very unsafe driving without a seatbelt.
