Weird problem brake lights not working
alright. i just got this integra. everything worked fine til i got it home. now my brake lights are not working when i press the brake. ive checked the button that is on the actual brake pedal. seems to be fine. all my fuses are good. and all bulbs are good. wtf is goin on.
Hint… If you want to troubleshoot the electrical in your car yourself, you will need a multimeter, or at the very least a 12V test light, having both is even better.
With just the test light you could test the fuse and for power at the brake light fuse.
If there was power there you would test for power at the input to the brake switch, if power there you would move on the the output of the brake switch, while stepping on it, and so on down the line till you find the problem. 94
