When my 93 teg RS goes above 4000+ RPM it makes a rattling noise, I can feel the rattle in the shifter. It doesn’t make the noise till I start deaccelerating, it’s fine as long as I keep the gas floored. Any help is apreciatied :argh:
did you just put in a short shifter with stabilizer bushing?
Nope, so far the car has all stock internals (Except Radiator).
lol
Re: Weird rattle at 4000+ RPM
Sounds exactly like your shifter bushings. you can replace them with new ones or you can grease the existing nut and bushings and they should be fine.
