weird seized up engine and tranny
doing the swap for my older brother got the ls out of another car that doesnt have title he drove it to the shop running fine the car was automatic i pulled the engine and took tranny off to put 5 speed tranny then put it into this car once i got everything straightened up we tried to start it it doesnt turn at all i used 19mm and 1/2 drive ratchet on the pulley couldnt even turn it with my feet WTF lol so we all made bet i thought i dropped socket in there while trying few starters my older brother thought engine is seized up my oldest brother thought it was flywheel so today took the tranny socket wasnt there (missing 13mm snap on deep socket thats why i thought it was in there) tried to turn motor again seems fine turned the tranny seem fine too so we took the clutch out to see if disc was on there wrong way nope it was on right way does anybody have this kind of problem before???
thanks guys
[QUOTE=demolisher;2267004]doing the swap for my older brother got the ls out of another car that doesnt have title he drove it to the shop running fine the car was automatic i pulled the engine and took tranny off to put 5 speed tranny then put it into this car once i got everything straightened up we tried to start it it doesnt turn at all i used 19mm and 1/2 drive ratchet on the pulley couldnt even turn it with my feet WTF lol so we all made bet i thought i dropped socket in there while trying few starters my older brother thought engine is seized up my oldest brother thought it was flywheel so today took the tranny socket wasnt there (missing 13mm snap on deep socket thats why i thought it was in there) tried to turn motor again seems fine turned the tranny seem fine too so we took the clutch out to see if disc was on there wrong way nope it was on right way does anybody have this kind of problem before???
thanks guys[/QUOTE]
sounds like an operator error
which flywheel and starter did you use? because manual and auto are different for both parts
we found out why it wont turn its because my brother got the 92-93 disc why do they make different internals for those years from 91 to 92??? WTF soo tomorrow will try to get her back on ground and see how she run
BTW we are using automatic starter which started the car today
Holy run-on sentences Batman…
what does that mean?
It means that you don’t use much punctuation, complete sentences or break your post into paragraphs… All of which would make your post much easier to read and, likely, get more good feedback.
Rather than mash three sentences in to one try breaking them up a bit.
