weird stall and odd noises coming from engine
update:
it was heavily raining and then my fender liner fell off and my CAI was left prone to water could it have sucked up enough water to hydrolock a rod?? that could explain the white smoke
UPDATE:
car iismaking this awful noise seems to get louder as rpms increase am i looking at a spun bearing or a broken rod??
please help =[[[[
what should i do low funds not sure if i will be able to bring my teggie back to life
so today i was driving home from school and than all of a sudden (cruising in 5th gear going 40) MPH dropped to 38 or 35 not too sure just thought i let off the gas. than i downshifted and tried to speed up butnothing… than the engine stalled. i thought maybe one of the vacuum wires got loose so i went under the hood pushed it in started the car kept going and than all of a sudden it started to smell and the engine stalled again. wtf is going on now i was almost home the engine started making a clunky noise (maybe low oil?) and then i turned off the car and walked home…
my temp guage wasn’t high or anything, weird smell, my fender liner fell off (picked it up) maybe water in the intake? idunno i need help thanks
okay so
UPDATE:
please help =[[[[
lol what? sell the car! fogetabboutit
maybe your map sensor came loose or your distributor is failing? check everything first and see if you notice anything weird. you should report back once you do.
so i got my baby home and it starts doesn’t seem to stall out (less rain) im thinking the cheapo intake that is on the car that doesn’t have the splash guard or fender shizzle got plugged? now its just making this weird clunking noise? it gets louder as RPM’s increase. low oil a little getting more oil later any suggestoins would love to keep my teg but very low funds =[
A clunking sound at idle that gets louder and faster with higher RPM’s sounds like a spun bearing or not enough oil (which means you are about to spin a bearing) to me.
dont think its a spun bearing but i will be getting more oil tomororw hope that is it
clean out your cai and your manifold with throttle body cleaner, get a new air filter, and seafoam your car.
but wouldn’t the rod still be bent?
You are overthinking it… your rod isn’t bending. Your rod bearing might not be too happy (the weird rpm related noise), but the rod isn’t physically bending
Could you give us a sound clip possibly ?
i believe the car is being towed to a shop going to find out whats wrong but keep you guys posted sorry no camera only an slr no video
