Weird starting issue
So about a month or so ago my 90’ Teg wouldn’t get power when I turned the key on. (The seatbelt woudn’t go back and no dash lights would turn on, and would only crank but no start) All I had to do was turn the key off and on again and it would be fine. Normally I would have took care of this problem earlier but it rarly did it. But then it would do it just about every time, and the car even died on me once, so I took it home and tried to figure it out. I’ve tried 3 other main relays and the same thing happens (All of them were off parts cars) Now it wont start at all. I cleaned the ignition switch and still nothing. Any help?..Sorry for the novel.
Sounds like the key switch is defunct. Try to get one from the wrecking yards or pick-a-part. A locksmith can change your tumbler for $20 so you’ll have the original key. Try searching in the electrical forum.
I dought thats it because when I had the ignition switch apart i checked the little thing in there that turns with the key and its fine. thanks anyway though.
Are you going to list this under the electrical forum? Better answers there.
done.
Swell!.
