Weird starting problems. HELP !
Not too sure if this is the right section but I hope someone can help me out. Not exactly sure how to explain this so bare with me a bit.
So my DA, which is all stock, has been acting up. I would try to go and start it and I would hear the main relay click and then the fuel pump priming but nothing from the motor hearing any signs of it trying to start/turn over. Did this several times and sometimes it would come up out of no where and try to crank over. I wacked my steering wheel out of anger and then tried it again and then I hear the motor clicking trying to start over and then it finally fires up. But this happens so often now that its not even funny. I dont know if its my main relay because it seems to be working fine. I replaced my battery hoping that would solve it but no luck. If somebody can point me in the right direction, please.
if your on the original starter. it possible that its time for a rebuild or replacement.
just to clarify, once the car starts. it runs fine. correct?
sound to me like a power problem as well, check both your 12v power cable and your ignition wire on the starter for good connections, engine grounds. if those apear ok, then the next things to check would be the starter relay and then the ignition switch. chances are its your starter thought…
yea im confused here, but is it a crank but no start situation, or does it not crank? big difference
