Was wondering which type of cell battery is good, Wet or Dry? I think I heard somewhere from here that Dry Cell battery is not good is that true? Just blew my battery the other day and was thinking about gettin the Password JDM Battery Relocator w/ the Oddessy 680 Dry Cell (http://passwordjdm.com/PasswordJDM-Battery-Relocator-DA-90-93-Integra-NO-ABS-P1901C354.aspx)… if not then gettin one of AutoZone’s battery
What is it you want out of the batt.?
What, other then starting the car, is the batt. going to power?
Also what is the reason for relocating the batt. from its stock location?:hmm: 94
Just for everyday DD uses mainly.
And i guess its probably not relocating but in the same spot but possibly located lower under the battery tray to hide it and save some weight from the oddessy 680
In that case, save your money, get the AutoZone batt. that fits the stock location, you gain no advantage going to a dry cell or a batt. relocation, if money is not the issue, by the best batt. that will fit the stock location.:sipread: 94
