I need to know… I’m too tall for this stock shit.
im not sure lol… buy iknow del sol and s20000 sit prytty low but those seats wont bolt in they need modification!
im 6’2 and i have da confetti seats they are ok in hight lol!
im 6’3 and i just put in a EP3 bucket in my DB1, love it!
i’m 6’5" so looking for the best option here. (mere inches make such a difference)
lol you need another car.
I’m way over 6ft tall and tried everything and the best solution to date are s2k seats on stock da rails that’s the way to go…
bolts right up? if not what’s the process?
anybody (or you) tried lowmax shit or w/e?
you should go with del sol or s2k seats… i have s2k in my car and they sit really low
If you use your stock seat rails they will bolt right up.
those s2k seats look so sexy in there…makes me wish i got those instead of my EP3 seats
bride gias low max sits super low, im 6’2 and im dumped in it
The s2k seats would look so much better if they were in cloth in the DA. So, it really just bolts right up in the DA on the stock rails? what about the seat belt mount?
I know this might not be what youre looking for but its an idea notheless.
I wasnt happy with the seat height using aftermarket brackets so i had a custom base made for the driverside. There might be 3/4 of an inch between the seat and floor pan now.
Looks exatly like this guys set up
BRIDE seat and rail … End of .
so can I just go out and get s2k seats without the rails and bolt them up with my DA rails?
oh an do they still slide fwd, I have kids and its a pain to get them in and out from the back seat…
Thats dedication. Replacing the seats… I’m 5’8 and It feels small enough, you must feel like donkey kong on mario kart.
I’m not sure there are many options besides completely aftermarket seats which may not be your style. I’m not sure how much lower they are, stock DA seats are already pretty low to the floor…
I’m interested in a seat swap right now and my options are slim for a factory look budget wise. I can do DC seats which but gota swap the seat pans and rails I think.
heres just to give you some stupid answers, not sure if they will work… probably wont go over to well…
- remove some of the foam from the bottom seat cushion… may be uncomfortable, its a metal pan under there.
- try to figure out some way to modify the rails, slot the mounts or elsewhere for adjustment if possible (may be dangerous, I’m not sure how to do it, I don’t suggest you try this unless you know what you are doing)
- Remove the interior roof liner, will probably give you 1-2 inches
- lean back
are the s2k seat wider in the lower section than the g2 seats, I wonder if I can bolt up the oem auto seatbelt or will I have to delete them or custom make something else. I dont think you can fit the center arm rest with these s2k seats.
Brides or something similar and buddy club super low seat rails ![]()
Del Sols sit fairly low. Im not sure which rails you would use, though.
I bought some bride seats and i ended up using the weapon=r seat brackets. they make you sit really low…
