what wire is the tps out pu t??? yellow red or green…
for what purpose? for ZEX kits, its the negative lead that you want to use for the Throttle position input…
the positvie lead gives a constant WOT input to the ECU. had a buddy learn that the hard way. Nitrous armed = whether or not your actually at full throttle or not w/ positive trigger…
zex
well it was the red wire and its easy to tell when the nitro is armed.u arm the switch with the engine off and press the gas.when u hit the floor u hear the solenoid click.
