okay so im building a lsvtec a b18a bottem end i bought a set of h beam rods that are 1.5mm longer these rods are for a gsr/ came with 10:1:1 comp ratio pistons i dont mind changing pistons but wouldnt i need to use a b16 crank? this is a boosted car btw
You can swap the b16 pistons on the Ls rods, that’s your best bet if you don’t have b16 pistons lmk I have a extra set I can ship you
But I’d use a compression that works best with your build you plan on going stock or swapping cams, but I would recommend b16 pistons on your Ls rods keep your stroke the same that’s the lsvs perk
