what do i need to install my jdm steering wheel???
what would i have to do to install this steering wheel??
is it a direct fit??
some say i need a momo hub adapter.
some say not
http://www.g2ic.com/forums/attachment.php?attachmentid=27316&stc=1&d=1203821900
For starters, fix your link.
whats wrong with it?? works fine for me
Says invalid $idname specified
that better??
nope still says it… are you using internet explorer??
yea im using I E. i know it sucks. i dont know how to fix it. you guys mean to tell me that none of those pics work??
the attached image works and the second linc does but the first one says invalid $idname specified
well that is the steering wheel what do i have to do to install it??
the gut i bought it from showed me a pic of it in a catalog and in was on a dc2. and i yahooed the wheel and i found a guy who said it was a jdm lude wheel.
well how about this… take off your steering wheel and look at the back of it and look at the back of this one and see if they are the same… all you ned to do to remove the stock one is remove the horn button (little advice take out the horn fuse first) and remove the nut from the center of the wheel i belive its 19mm, then just pull the wheel off and unplug the cruise/ horn plug at the bottom on the back. there will be a small square metal pice with two things sticking out on each side around the colom for the turn signals and a large plastic circle pice with two things sticking out of is for the cruise/ horn wires (you will see what im talking about when you take it off) if there are groves/ holes on the new wheel for these to hook onto then it should work if not then i dont know really what to tell you… i dont know a lot about steering wheels on our cars other that you dont need a puller to take them off!! but good luck with it!!
it has 6 holes in it like i am supposed to connect it to a hub adapter. but someone said that a momo hub adapter wouldnt work wit it. ill try to get pics of it
If that steering wheel is a Momo (looks like, based on the horn button), Momo (Personal and a couple of other brands that slip my mind) adaptors should work. If you have cruise control and want to use them then you need a special adaptor for that. I didn’t know that such things existed a few years back so I Jerry-rigged the non-CC adaptor that I had in my non-CC Civic to accept the CC switches on the wheel.
yes its a true jdm momo . it has the 6 holes in it and 3 different plugs
http://www.t-mobilepictures.com/photos/photo32/54/24/9e9872a96ce4.jpg?_rh=9iiv3ybo6fpw0kme8mq5q0ro9
http://www.t-mobilepictures.com/photos/photo33/8e/55/bb08cb91bb20.jpg?_rh=5hrbuqmnnevtujtvm1ie15y9z
http://www.t-mobilepictures.com/photos/photo31/e8/5f/8132a65f34d4.jpg?_rh=71wbo2j4728cxngrortzrfj6x
sorry for pics being so dang big.
im thinking that i just need to get the momo hub adapter or an nrg hub adapter with a momo mount plate.
