I know that 14 is the Idle air control valve
and that
7 is the Throttle position sensor.
but is there anything in specific i should be looking for when they both are being
given?
and that
given?
Why would you provide a link for Prelude ECU codes when the Teg Tips already list the codes. :bang:
[QUOTE=spikeymike;2176833]Why would you provide a link for Prelude ECU codes when the Teg Tips already list the codes. :bang:
http://forums.g2ic.com/tegtips/engine/13.html[/QUOTE]
Because i couldn’t find it and the code’s should be all the same.
[QUOTE=TRiVDA9;2176822]I know that 14 is the Idle air control valve
and that
given?[/QUOTE]
Since you already know what the codes mean, the other posts telling you what each code means is irrelevant and have been removed.
Regarding CEL 7 try:
http://forums.g2ic.com/showthread.php?179823-CEL-Code-7&highlight=Throttle+position+sensor
