what ecu with ls/vtec?
i’m building my block right now, but just for ahead of time, i was wondering what was recommended and which would be best for ls/vtec. right now i have a spoon ecu which has really good fuel enrichment when vtec is engaged. but its a b16 ecu. and with the motor being a b18a bottom end, what should i do? should i just get a v-afc? any ideas?
If you already have a vtec ecu with spoon program I would suggest getting the vafc you mentioned.
stand alone is the way to go! NON OBD is very limited to programs! I’m still in search for one!:up:
Let me tell you what you NEED to do as I have studied this in great detail.
You need an obd1 ecu controlled by a hondata ecu management setup. Any obd1 ecu will do while using hondata but the one to get would be the p72 from the 94-95 gsr. You can also use one from 92-95 civic, 92-95 teg, and prolly some others but those’r the ones i know for sure. If you have a 90-91 teg, you’ll need an obd1 distributor, and some other ignition pieces which I can get you the part #'s if necessary. The Hondata setup is the only way to maximize an ls/vtec setup. A cheaper way if you’re on a budget is to just buy the p72 ecu and hook it up to your setup. Any other ?'s lemme know- gen2tegb16a@hotmail.com HTH
well here how do i hook it up do i have to get a new harness for this to work or do i have to like splice wires in certain spots.
that’s something me and my mechanic are working on right now. He rewired his car completely but that’s cause he prolly had a slow day at the dealorship and nothing better to do- THIS IS NOT FUN for normal people like us. He told me to get an obd1 ecu, which I did- a pr4 from a 5sp gs G2, and cut 2 male harnesses going into the ecu from junk cars- I’ll let you know as soon as I find out what his intentions are for this or if I can think of an easier way to do this. HTH
