what exactly is a crank girdle?
i know its something to like keep strength so you don’t spin an rod bearings, do ls blocks have them? if not, can you get them installed, cause it seems like a good idea for one of the worse r/s ratios for high reving… thanks
LS blocks were not built with them but GSRs were. You are correct about strengthening the main cap area.
This one example available from Z10
thats one of the reasons why a poorly built ls/vtec can fail
Originally posted by AMERIKAN
[B]LS blocks were not built with them but GSRs were. You are correct about strengthening the main cap area.
This one example offered byt z10
John - how much do they run?
Thank you for this post.
Josh
Originally posted by bigblue92
[B]
Josh [/B]
$289. Go to www.z10eng.com and go to Products on the pull down menu to the right. Its the first item.
-Steve
I noticed this on z10’s web site:
NEEDS!
*GS-R / Type R
Main Bolts, Windage Tray, Oil pump pickup
So basically if I buy the girdle I would still need to buy those other parts???
Yeah, when they say you need them, they’re not kidding. The GSRs and ITRs were designed with girdles while our engines were not, so our parts don’t fit properly.
