hey wassup g2 …what would happen if i compeletly remove the abs resevoir n the abs accumlator???lmk
Well, if you just remove those parts and don’t replace 'em with the correct non-abs parts you’ll have completely non-functioning brakes. :search: we’ve covered the ABS removal topic a lot.
I got a prop valve that you’ll need lol
Your brakes would not work…that’s what will happen…this is easy to do…
so what you can only remove so far if you have not plan to do the conversion without messing up your brakes is the abs sensors, abs box that is on the passenger side panel next to the rear seats…
iight ill see what ill do…
