I have searched and searched, but the only thing that has come up is what interchangeable between acuras & Hondas is the prelude. If you know or know a link as to what parts are interchangeable between all Hondas and acuras, for the 90-93 Integra please post it. And if this is in the wrong section please tell me and tell me where to put it, thanks in advance my g2ers ![]()
What are you wanting to interchange? The prelude would have the least amount of interchangeable parts when it comes to an Integra.
Lol anything and everything. I wasn’t asking what’s interchangeable between the prelude, I was just saying thats all I could find is other vehicles interchangeable with the prelude. Basically, if you have seen the thread about suspension interchangeability with the EF/EK, is what I’m looking for. For an idea, I know the accord lips are interchangeable with some mods, Taurus cup holder/ coin tray works with a little trimming, same as side skirts from Taurus and accord. I know for the most part B series engine parts are interchangeable. Things like that, from ground up.
From brakes to suspension, from OEM body kits to interior stuff. And I know anything will work with modifications, I’m just looking for stuff that isnt any MAJOR mods.
Google is your friend and from what you are telling us, you aren’t searching hard/in depth enough to find answers. I don’t know about aesthetics, but I can give you an idea of whats interchangeable in terms of brakes/suspension.
Here’s a brief summary of suspension:
DC2/EG:
-Front and rear suspension will bolt up, but you will need the front forks and it may rub the axles and overall the strut is about 2.5’’ shorter than DA applications. ITR work as well but you’ll need rear control arms. I’m pretty sure EK works as well- I forget.
-DC2/EG rear trailing arms
-Anchor style front camber kits
-Rear camber kits (aftermarket, adjustable)
-Rear toe/compensator arm (aftermarket, adjustable)
-Shift linkage
EF:
- Strut bars
- Various suspension bushings (you’ll have to cross reference part numbers)
- manual steering rack (will need conversion kit)
Brakes:
-Type-R front and rear calipers (98-01 only for the rears)
-Legend- front calipers
-NSX front calipers (need to mill the bracket for sure, I forget if the other ones require it)
-S2000- front calipers
-RSX- rear calipers (need to reverse mount them Left caliper on right side and etc- makes it a pain to bleed them)
-If you decide to swap to a bigger caliper, retain the 1’’ BMC that came equipped on ABS-equipped DA’s for a more firm brake pedal
Like I said, google is your friend- search harder ![]()
Haha thanks man. I geusse I just don’t know how to word it for google to understand what I’m asking. All I was able to find was the prelude, and what interchangeable between a 2 door and a 4 door. But thank you for some info. Anymore from anyone is greatly appreciated ![]()
And yes, I will keep searching lol. I’m always searching stuff up on my G2
Are you trying to figure out what from other cars is interchangeable as far as upgrading?
You aren’t being very specifik here…
Haha this guy ^. To be I honest I don’t know how more specifik I can be. I’m looking for parts that are interchangeable with the g2 Integra from other vehicles whether they are Hondas, other acuras, or any other make and models. Something like this. This is from preludeonline.com.
Coilovers: 92-96 Prelude 90-93 Accord 89-01 civics 90-01 integra
Intakes: 92-95 Civic (Dosen’t fit alb models) 98-01 Civic 92-96 Prelude (With battery relocation) 94-01 ITR intake (fits with battery relocation) 94-01 Integra LS 3 piece CAI intake No mods required
Front Lips: Early 90 year mazda 626s 88-91 Crx Si 1st gen integra lip (86-89) 2nd gen integra lip (90-93) 94 accord ex fits but with major work, needs to be cut and molded.
Rear Lips: 94 EX honda accord
Side skirts: 94 EX 2 door Accord ( I imagine all accords from that generation since they are the same, wrong?) 92-96 Prelude OEM sideskirts (Just need cut a little) 94-01 Integra Sideskirts 5th Gen Sideskirts (need cut)
Front Bumpers: 90-93 Integra (W/ Slight mods)
Rear Bumpers: 00-01 Civic Ex
Rear Spoilers: 90-93 Integra OEM Spoiler (Just have to trim down the middle support) (All Years) Pontiac Fiero OEM Spoiler Maybe 97-01 5th Gen OEM Spoiler
Alternators: 94 Accord 2.2 stock and aftermarket up to 110amp Acura Legend up to 120 amp
Fuel System: 92-95 Civic Fuel Pressure Regulator 450cc Injectors All OEM Turbo Eclipses/Talons/Laser
Tranmission: 92-96 Si Prelude Quaife LSD (Works on only 90-91 Tranny w/ mods)
Engine Misc: B-Series Cam Gears B20b Cams b18b Cams-b21 only? Rods from H23 Pistons from B-Series Motor 94-01 ITR stock LSD fits the 90-91 tranny with mods. H22 dual valve springs (boostedlude3g)
Brake Pads:
Front: Honda Civic 1990-93 EX Honda Accord 1989 Coupe Sei Honda Accord 1988-89 Sedan Lxi/SEi Acura Legend 1986-90
Rear: Acura Integra 1994-01 Except Type-R & RS Acura Integra 1990-93 Honda Accord 1989 Coupe Sei Honda Accord 1988-89 Sedan SEi Honda Civic 1990-93 EX Honda Civic 1994-95 Sedan EX/LX, w/ABS Honda Civic 1988-96 H.B. 1.5/1.6L CX/DX/Si/VX (w/o ABS) Honda Civic 1999-00 Si DOHC Honda Del Sol 1993-97 S/Si w/o ABS 26-200
But I’m looking for Integra interchangeability. I can assume that some of that will work the same with the g2 because 90-01 Integra is on there that can be put on the prelude
[QUOTE=specifik;2319346]Haha this guy ^. To be I honest I don’t know how more specifik I can be. I’m looking for parts that are interchangeable with the g2 Integra from other vehicles whether they are Hondas, other acuras, or any other make and models. Something like this. This is from preludeonline.com.
Engine Misc:[B] B-Series Cam Gears B20b Cams b18b Cams-b21 only? Rods from H23 Pistons from B-Series Motor 94-01 ITR stock LSD fits the 90-91 tranny with mods. H22 dual valve springs /B
Brake Pads:
Rear: Acura Integra 1994-01 Except Type-R & RS Acura Integra 1990-93 Honda Accord 1989 Coupe Sei Honda Accord 1988-89 Sedan SEi Honda Civic 1990-93 EX Honda Civic 1994-95 Sedan EX/LX, w/ABS Honda Civic 1988-96 H.B. 1.5/1.6L CX/DX/Si/VX (w/o ABS) Honda Civic 1999-00 Si DOHC Honda Del Sol 1993-97 S/Si w/o ABS 26-200[/QUOTE]
See that part does fit, H series rods on B series pistons?
I have no idea what that list is for, what car they are referencing these parts fit into or whatever.
If you gave us an idea of what you are trying to do that would be super. I don’t know if you are just making a list for the hell of it, looking for upgrades for your car or whatever.
PRELUDE bro. Lol I know I put it in my comment that this list is from preludeonline.com. my plan is to be able to interchange things if needed. Like “the ever elusive hybrid DA suspension” thread at the top of the list of Archives. As he says that the DA has been a red headed step child, instead of having to find a part specifically for my car, I could change a part, like using the ek/ef/eg suspension I just need to take a certain part ( cant remember) for that suspension to work and then because of that it seems there’s more of a veriaty, at least for suspension, for the civics and 94+ integras.
And not to mention my local junkyard doesn’t have to many 90-93 tegs but plenty other Hondas and acuras. All I’m really asking is if anyone knows a link, I’m not totally asking for you guys to just tell me or search for me, I’m just looking for direction.
[QUOTE=AV turn’d DA;2319315]Google is your friend and from what you are telling us, you aren’t searching hard/in depth enough to find answers. I don’t know about aesthetics, but I can give you an idea of whats interchangeable in terms of brakes/suspension.
DC2/EG:
-Shift linkage
EF:
- Strut bars
Brakes:
Like I said, google is your friend- search harder ;)[/QUOTE]
i’m doing some digging on DC/DA compatibility. A friend of mine has some Wilwood calipers that will fit a DC. I just want to confirm that all DC caliper/caliper bracket are interchangeable w/ the DB1
i see it says DC2 front and rear calipers…this translate to all DA/DB1/DB2s being compatible w/ all DCs caliper/caliper bracket. like just swapping out caliper brackets i can utilitze the calipers of a DC on a DA?
If this has been said sorry in advance. You can do a big brake/ five lug conversion from a acura legend
i just want to know if the DA and DC front calipers are swappable. if so is anything special needed? asking that to ask if i can use the wilwood DC calipers on my DA
