what is this terrible shaking?
if I stop quick my car shakes freakin violently I want to know what it is and how I can fix it, I’m also not sure if it’s because I need to wear in my brakes.:shrug:
Shaking
Have you checked your front tie rod ends? I thought that I had a bent rim until I took off both wheels, and tried moving the disc around. If it moves up and down, it might be a wheel bearing, if it moves left to right, it might be the tie rod end is worn…HTH…
it could also be a warped rotor. you said you need to wear in your brakes, so that might not be it, but warped rotors gives ya nasty shaking when you brake.
