what makes the light dim???
gauges…headlight…dim when i step on the brakes and press the power window and power lock switches…
battery? alternator? thanks
you got it…battery or altenator OR both… probably just a tired altenator. try checking the voltage of the battery when the car is on and when it’s off…when the car is on the voltage should be around 14.5 to maybe 13.?? and when the car is off it should be around 12.85. How old is your battery? If it’s still new then you need a new altenator…OR check the battery cables…they should be a tight. And also check the 2 wires that screw into the fuse box. they should also be tight for the altenator to keep the battery charged.
HTH
jImmy
thanks…how do check the battery voltage???
i dont how old my battery is…i havent change the battery yet since i got the car…2 yrs ago…
and the two plugs onto the ecu is tight so as the battery cables…
Most parts store will check your battery voltage for you. You can do it at home if you have a volt meter.
buy a cheap multimeter, you will use it again sometime. They can be had for $15-20 for ones that will last (dont but the $5 ones)
