What mugen pedals fit the 1990 to 1993 teg are they all aftermarket and fitall hondas/acuras. 2nd does it matter what mm say 350mm wat ones fit my 1990 integra so i know wat wheel size to order. For the personal steering wheel.
a steering wheel is a steering wheel. the size (usually in mm) only determines the diameter, so if u want a small one u get a small one like a 300mm or less. if u want big then get a bigger one. its that simple.
regarding the pedals… any aftermarket 5spd pedals (really are covers) fit. how well they fit is determined by how u put it on, and whether or not u got the patience to make them sit just right.
just remember when buying a steering wheel that smaller means more turns of the wheel to turn the car and bigger means less turns. keep that in mind if fo sho you are turbo and no power steering.
and if you do want a smaller steering wheel…the stock ones are aroudn 370mm …i have a 350mm Personal wheel waiting to be isntalled and its only a little bit smaller
