I’m wanting to put an oem Honda cd player in my da. Which one, if any, fits best in the oem location using oem parts? I know I will need to change the harness but I’m talking about the plastic pieces.
Thanks!
Your G2 takes a single din, rear mount HU w/pocket attached… http://www.installdr.com/InstallDocs/Acura/PDF/466049.pdf the radio harness plug is the same on all Honda/Acura from 1989 - 1997/98 with standard radio, [non Bose systems]… http://www.installdr.com/Harnesses/HA-Wiring.pdf
Even some later models of Integra used the same plug, [99-01], so just about any Integra HU will work, [check plug on back of HU].
Just about any single din or double din Honda/Acura HU will fit and plug in, [89-98] some mods may be needed to mount the HU.
This Accord double din… http://www.installdr.com/InstallDocs/Honda/PDF/466053.pdf where the side mounting brackets must be cut off and a rear mount bracket made and an adapter plug made to go from your radio harness plug to the later model plug on the back of the HU, adapter plugs can be found at most car audio shops/install bays. 94
Anybody else? I know it takes a single din but my concern is I want it to look oem and fit in the alotted space correctly.
It will take a single din with a pocket or a double din.
As stock as possible would require an Integra HU, [Acura] as apposed to a Civic/Accord HU, [Honda].
http://cgi.ebay.com/ebaymotors/97-01-ACURA-CL-INTEGRA-RADIO-CD_W0QQcmdZViewItemQQhashZitem2eaa9636cfQQitemZ200430466767QQptZCarQ5fAudioQ5fVideo
http://cgi.ebay.com/ebaymotors/02-03-HONDA-S2000-AM-FM-CD-Radio-Player_W0QQcmdZViewItemQQhashZitem58859cc430QQitemZ380198765616QQptZCarQ5fAudioQ5fVideo 94
