What other seats fit?
Just curious what other honda/acura seats will fit? I did some searching but I had going through thousands of pages to find a direct answer.
dc/eg seats will fit with modifications, basically swapping the rails.
i’ve also seen RSX seats in a DA.
How would you make s2k seats fit? I can I use stock da rails on it, right?
By the way, sorry to thread jack
i have s2k seats in my integra, I had to modify both the integra and s2k rails to fit took me bout 6 hrs to do both seats, but it is well worth it
Nothing bolts in. 3 out of 4 bolts is not a bolt in and unsafe.
RSX seats fit after swapping the rails but sit high, only way to fix it is to chop the seat frame.
what did you have to do to modify it?
Swapped the rails and now I have to cut the seat frame down and reweld it.
I’ll my how to later today.
How did you get them to fit?
He most likely swapped the DA rails to the s2000 seats.
I had to grind off the s2k seat rails and sliders and shave and trim the stock integra rails so that the s2k rail would seat flush on the integra rails and weld everything together… hope this make any sense
Will EF seats work?
What is the easiest seat to swap in with not alot of modification? my current da seats are near mint except for the drivers side has a rip so yea.
the easiest would be stock 92-93 seats, the fabric is better and doesnt rip as easy like the 90-91
I have a 92 lol.
ive got 4th gen prelude seats in my db1.
What do the prelude seats look like? Do you have pics? The only prelude seats I’ve ever seen weren’t that attractive. I thought they looked way to tall and narrow. They weren’t that new though. I’d be interested in seeing them put in a da.
here ya go
Those look alright. I don’t really like the top part of the seats but they look like they match your interior really well. Its different. Did you prefer the look of them or were your stock seats in bad shape? Either way good job on the install. Thanks for the pics.
Edit- If they were in a da it would be really cool to use the armrest and backseats too. I don’t think it would reach for a 4 door. It might not even be close to fitting a da either. I saw a set in a junkard and thought about trying the conversion back then but decided against it.
i love the seats i had a 4th gen prelude and when i got my db1 i decided to try lude seats in there…
those are some nice seats. I have a tom motorsport seat, I need to mod the bracket though. or just get a new one.
