ok does anyone know what that thing do??? my strut bar is kinda hitting it and someone said i can just remove it, just wondering what u guyz thought of the idea of removing it, that piece gotta serve a purpose
that should be your idle control. and if i were you id bend the strut bar to make it fit right. thats wat i did
search, it has been covered before.
keyword: dashpot valve
dapnoy: no, that is not the idle control. please do not post incorrect information if you don’t know what it is.
and use a better title or your thread will get closed.
http://www.g2ic.com/forums/announcement.php?f=29&announcementid=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
