Ok, so someone locked my last thread about pulling an aero kit…
Still need help, can someone explain why it was closed? And maybe I can get an answer to the question too? WTF?
Try reading the forum rules, something that you should have read in the first place when joining this forum, to avoid your thread being closed. If you’ve been here longer than a year, you should know better. :tapfing:
http://www.g2ic.com/forums/announcement.php?f=31&a=13
USE APPROPRIATE SUBJECTS
Your subject should be a broad description of what your problem/question/topic is. For example, don’t post a thread with just “HELP” or “QUICK QUESTION” in the subject. Doing this will be regarded as pure laziness and the thread will be promptly deleted. Using appropriate subjects helps the search engine function better!. Also, do NOT use a different subject than what your thread is about, just to get attention. It will also be deleted.
Many appologies… I guess in my haste to try not to let a super rare body kit go to the crusher or some hick ass junk yard, I forgot to put in that info in the subject line, I will repost it.
Thank you.
