I am building a ls vtec turbo motor and cant seem to find the right answer to my question.which throttle cabe do i need for my set up.93 ls with 95 gsr head.i appologize if im posting in the wrong place but i am new here and didnt see anywhere this question was asked already
what manifold are you using.
its a skunk 2 style.its got the two holes for the type r bracket and i was told my ls cable will work with that bracket but i dont think so,it doesnt look like it would anyway
I’m using an ITR manifold with a PR4 bracket. As you can see I’m only using one bolt/hole, but it holds just fine.
Your LS cable will work just fine with the Skunk2 manifold + ITR throttle cable bracket.
Sean, bust out the drill and the dremel! You can easily modify your bracket to at least look like it’s supposed to be there
that or buy a p73 cable.
[QUOTE=Colin;2292913]Your LS cable will work just fine with the Skunk2 manifold + ITR throttle cable bracket.
Sean, bust out the drill and the dremel! You can easily modify your bracket to at least look like it’s supposed to be there :)[/QUOTE]
Hahah yeah yeah yeah. Nothing a grinder and drill won’t solve.
I didn’t see the point in buying a Type-R bracket or cable. I will make it fit proper, just for you though!
No need to buy the cable, the bracket is all you need.
i bought the bracket and running into a different problem,the 95 gsr throttle body has the cable coming in from the other side so the cable is gonna hook up backwards.do i get a different throttle body or should i just replace the throttle blade?if so what blade or throttle body will work with my set up
