what to buy for msd setup
I have a 90 integra with a b17 swap using obd0 b16 distributor and obd0 pr3 ecu im not sure what msd kit to buy the one for the 90 integra or the one for 94 and up gsr and type r integras…thanx for the info
Why do you want an MSD setup?
The stock ignition is good for anything you have.
+1 unless your running nitrous, but then your using the msd for ignition adv/ret control and a window switch, not as an ignition upgrade
Ive always wanted to have a msd ignition setup my rx7 has one cuz it needed it…I just want one for my da my b17 isnt quick like it should but it can be if u have any advice for making it quicker but reliable let me know
I have MSD set ups for your car. www.dasbydesign.com. However, you did say that your DA isn’t quick. I honest would start with the basics. Make 100% sure you’re engine is strong. IE) compression test, leakdown. Check your spark plugs, replace your fuel filter. Are you running a catalytic converter?
What mods do you have done to it?
Spray it with a 100 shot. get a clutch, some head studs, a timing light, and some 93 octane.
The ignition system on our cars is completely capable of 400whp+ before anything needs upgraded.
Cheap and easy power will not come easy in a small 1.7L motor. Aside from your basic IHE upgrades, you need forced induction (turbo, nitrous, etc) or internal upgrades.
Full intake system and full exhaust system will liven things up a little bit. Otherwise, you’ll have to start shelling out some cash to get decent gains.
[QUOTE=unified112;2311159]The ignition system on our cars is completely capable of 400whp+ before anything needs upgraded.
Full intake system and full exhaust system will liven things up a little bit. Otherwise, you’ll have to start shelling out some cash to get decent gains.[/QUOTE]
planning on doing a full build on a obd0 b16a everything head wise will be skunk 2 and lower end I plan on just ctr pistons and see if I like it our not
Some light reading regarding B17 builds and power results. Some list their dyno sheets, some don’t.
http://forums.g2ic.com/showthread.php?137294-B17-all-motor-builds-please-post-your-builds
