What tranny do I have?
Im at work right now so I can’t go out and get the code off the tranny but is there a way by the color of the tag to tell what tranny I have? I was told I had a gsr tranny. It’s an LS so I don’t know why they would have put a gsr tranny in with the stock b18a. I’m a little weary of it.
What tranny is best mated with a jdm b16a for my 92 2 door?
Stick with a b16 tranny or a ITR tranny, both close gear ratio’s, enables you to be in a slighty higher rpm in every gear, compared to the gsr tranny. But if you want to keep your car a bit torquey, then the b16 or ITR tranny would be great. But any of the three will satisfy you, just keep away from the LS tranny when running a b-series vtec motor.
That’s what I think I got, an LS tranny. So b16 cable or hydro? And how much installed do you think I should be looking at?
Cable. Easier to fuck with; both in install & adjustment.
:getsome: :manual:
So yeah, my reverse went out in my da. Took it to Honda they said there’s either something bent or broken in there. So, I’m in the market for a new one. Most likely going with a B16 since. Will definitly be an upgrade from my ls tranny…yuck. What price should I be looking at installed? I’ve talked to 2 different shops and they are quoting $1200.
