Whats the biggest rim and tire package that i can fit in the DA integra, without special modifications. Could i fit a 15x8 or a 16x8 in the wheelwells, what would be the offset for these if they could fit.
20’S Yo !!!11!
good question, i would also like to know. it might rub the fenders. maybe like a 16x8 +20 offset? spacers?
I have a 15x8 wheel with no problem
hey but whats your offset on those 15x8
Honestly I don’t know! I traded for them and forgot to ask, but I will find out. they are Motegi MR12s if you want to check…
15x8/16x8, while they will fit, are not a very common size and more often than not you’ll have to special-order or pay a premium to get them.
but yes, they will fit. as for offset, that can vary with suspension setup, alignment specs, ride height, etc. a +35 wheel on one car may rub on another with different settings. gonna have to play it by ear on that one.
How do you figure out your offset? I have no problems with rubbing or even camber/caster. My DA is lowered at least two inches, I’m not totally sure on that one and I have no issues.
should be marked on the wheel, usually on the inside (as in brake rotor side).
see cause i found this guy on myspace that has a company and he put like 15x8 0 offset, but added these fenders.
Axis wheels has a reasonable priced 15x8 wheel that should fit our cars…Is anyone running this wheel The Axis Oldskool—check the link from modacar.com
http://www.modacar.com/Merchant2/merchant.mv?Screen=CTGY&Store_Code=M&Category_Code=AXISW&Carb=All
are u talking width or height? be more specific. cause u can fit 19’s on a DA but i know someone who has his wheels widened to like 9.5 inches and didnt have to do a damn thing… looks REALLY brown pride tho.
no i want width for a bigger contact patch
7 should be plenty for you.
you can toss up to a 225/50-15 on there…really no benefit to anything wider.
^ werd. ull actually strat losin performance id imagine. i have 8 wides and am getting rid of the, for something smaller. they look cool from the back but then u realize its a teg and not a camaro. lol.id say 7 7.5. no more. u wont like the way it affects the handling. at least i didnt… felt like i was out of power steering fluid. lol
yeah I think it starts looking stupid at a point…like when I had my wheels on my old CRX, the 205mm width made the wheel stick out and I just think that looks tacky on imports. Just using that as an example…
